I have used a few online calculators to make a chart to compare the weight, yield and buckling load of different size steel tubes to use for car suspension links but I have no idea if it's correct or even correct enough to be of any use.
I used this moment of inertia calculator, https://calculator-online.net/moment-of-inertia-calculator/ and this for the buckling load, https://www.omnicalculator.com/physics/buckling
For a tube 31.75mm OD, 27.69mm ID, 2.03mm wall thickness, 600mm long, Young modulus 186Gpa, yield 370N/mm2, pinned-pinned k factor 1.0, I got a moment of inertia of 21013.75mm4 and a buckling load of 58664N.
Would someone please check if the calculators are correct? Tubes from 1"x16g to 1.5"x12g appear to have a buckling load from 75% to 88% of the yield in tension, does that sound about right?
