Hi,
Since I've been in about the innards of my Migmate 150DP it got me wondering whether I could rig it for stick welding as an additional option. I was thinking along the lines of wiring a hefty DPDT switch, one position would bypass the switch on the torch with one pole, and isolate the wire feed motor with the other pole.
Before I investigate how to get at the appropriate connections, is there anything fundamentally wrong with this idea, in that the output would be unsuitable for MMA? Also, which polarity should I use, torch +ve or torch -ve?
Thanks, Tony S
Thanks, Tony S
