Do you have a power supply to the shed, if not cable run and size needs to be taken into costs?So, I need to fit a 32a socket to power a welder and a plasma cutter. They will be used in the shed outside. How much would it be to supply and fit it? Rough figures please.
Consumer unit is in the living room by the house's front wall. I can put the 32a socket on the other side of the wall outside pretty much opposite the consumer unit.not enough info. How far from consumer unit for a start would be good. Are you supplying the cable? underground or overground?
When you say most of the work, do you mean drill a hole through the front wall myself?next question. Do you know a good electrician? I would think that you could do most of the work yourself, and get the sparks to do the final connection,
They can remove the 13a socket and cable for me and replace with a 32a I expectTake advise from your qualified electrician. They will tell you what you can or cannot do
