zardoz
Old school Socialist
- Chetser, UK
I am doing TIG City and Guilds level 2 at evening class. I jumped straight to level 2 as there were no places left on the level 1 class, and I had done a few classes at TIG and can Oxy ace to a reasonable level, so i crossed my fingers and joined up. I am now getting the hang of it, and have passed the first of five test pieces, with a butt weld tested with a cupping test and found no splits in the weld. I started to look out for the reflection of the TIG arc in the pool of molten metal (as my tutor advised me to look out for) and was amazed as i actually started to be able to see its reflction in the liquid metal weld. The tutor tells me if i touch down with the tungsten, to stop and change or re grind it, which i now always try to do if i notice a touch down. Though sometimes even when i have been sure not to contaminate the tip by touching down i still seem to get contamination in the weld pool before i have finished my run. I can see this as I can no longer view the reflection of the tip in what appears to be a now dirty weld pool with "scum" floating on the top.
Is this being caused by contamination of metal from the area surrounding the weld as it heats up I always grind the edge around the weld to 6 or 7 mm back, but my tutor says that 12mm is prefferable and on both the weld side and the rear. (we are using 1.6mm steel) and using a rig to send purge gas to the back of the weld.
Would any TIG heads on the forum say that grinding 12mm back from the edges on both the front and rear of the weld is correct, or is my tutor being a little too, belt and braces?
PS: TIG is excelent. I am saving up from now on. Too bad ill need over a grand to get a decent ac/dc kit coz now im out of work it'll take forever and a day to save
