half bricks and sit mesh on top![]()
Just get the concrete down, throw the mesh on top and then walk about on it / jump up and down on it (depends upon the slump) until you have the required coverage - this method has been sucessfully used for many generations of construction workers, and if you wash your wellington boots afterwards they can last for many square miles of surface
BUT IF THEY ARE WRONG not many argue the pointMust be right , a thousand pikeys can't all be wrong .
Cut a piece of mesh and bend it downwardshalf bricks and sit mesh on top![]()
Very nice , more spacers needed if well nourished chaps like myself are nipping up !
Where did the 4" pipe - bottom left - go ?
Remember my first experience steel fixing. Anything but simple. Wet site, footings with complex steel Reinforcing which the supported mesh across the slab poured in one hit. Level changes left right and center. Gulley's formed in the slab for drainage. Steel left protruding to tie concrete reinforced walls and then ceiling in. Sure the pics of the steel are lurking somewhere. Probably on my old iPad.
