cumbriasteve
Moderator
- Cumbria UK
Yes nothing to do with steel and welding but this forum has proved time and again it has a wide range of expertise amongst it's members...so here we go:
Relative has had a drive laid 2 days ago, being a bit strapped they have used a cowboy firm and the results show that.
it is covered all over with deep float marks, some as high as 25mm.
I can remember my garage floor had some and I rubbed a brick over them, it worked well and flattened them back but I think I also read somewhere you can pressure wash a newly laid drive to 'polish' it and remove float marks.
Will it work? or is there any other non costly method apart from that and the brick method.
float marks !! sounds more like shovel marks, 2 days you will be struggling, you could try a large concrete block with two people, I did some with a concrete block with two people and rotated it, back and too, with water,but not loads just so the holes will be filled with the fat you make, like grinding valves in, thats ok if the trowel marks are just the concrete 'fat' as it is called, big problem if there is aggregate in the lumps and you pull the stones up. i dont think a pressure wash will work.
