Kram
- Sussex
Compressor has been buried behind other tools for nearly 4 years in a dry shed without any use. I got it in 2017, so 9 years old.
In total its had very few hours of use, its still on the original oil - perhaps time to change it..?
Turned it on today, first issue is it did not appear to cut off or, went slightly into the red part of the gauge and I stopped it just in case.
The pressure relief valve felt stiff and wasnt easy to manually pull, and stuck out. After a few pulls it seems to be moving freely like it should. Should I apply some lubricating oil to the PRV?
Any other maintence to do?
The tank was always drained before storage, so rust should not be a problem.
I'm a bit fearful of letting it run up to full pressure in case it doesnt want to cut out and the PRV failing to open.
I'll watch it closer when I try it tomorrow!
