angellonewolf
- bristol england
Ok I'm in the need for a compression tester I've bought a sealey ct955 v3 its carp and this is the 2nd one
are the chrs0 ones any good
In what way is sealey no goodOk I'm in the need for a compression tester I've bought a sealey ct955 v3 its carp and this is the 2nd one
View attachment 175097 are the chrs0 ones any good
It will show issues, ie a cylinder that is lower then the others, test dry and then a teaspoon full of oil into the cylinder can show either leaking head gasket or valveNot if there is a underlying issue.
I have a Sealy and a Halfords, both do a Ok job.
But a compression tester will tell you if you have compression. Not if there is a underlying issue.
Most people only do a dry test and miss out a wet test.
I have that same sealey kit. I can't vouch for its accuracy but it's been fine for giving an indication or for seeing if the compression is balanced.
The only issues has been the grade of rubber on the o rings, mine all crumbled away after a few years.
can you replace them ?
