DAPPH
as dyslexik as I'm daft
I'm looking for advice about acid etching fine turned steel , brass & aluminium to a depth of about 20 thou deep .
As the actress said to the bishop, " I've not done this before ".
We have an acid proof glass or plastic receptacle to carry out the etching in .
I'm considering etching some bigger home made reference dials with larger graduations and numbers etc. than those that are currently for my lathe , as my eyesight & fingers need all the help they can get these days
On youtube , I've seen guys being bent over their lathes for hours & hours using the carriage & / or compound slide & a stop block to gouge out the scale devisions .
Having two knackerd shoulders , two spinal disabilities and awaiting a new left knee precludes me even considering such an exercise not to mention an old mans eyesight levels .
On ebay I won a second hand but unused precision cut six & a half inch diameter circular saw blade that has exactly 100 teeth cut into it .. I'll be making up a simple tool that uses this as the reference marking point device , for the lathe scale is one division equals one thou of thread advancement per graduation , which gives 100 thou travel per 360 degree of rotation .
My thoughts are :
Use meths to clean the turned part after giving it a boiling hot water scalding to remove as much crud as possible .
See if I can buy a small tin of etch resist lacquer/paint ( Is this available these days? ) .
Draw my designs with a triangular ground up bit of stellite rod & /or tap a fine ground chisel form blade made specifically for the purpose from bit of key-way steel into the metal .
I also hope to use a set of small number & letter punches in a special homemade sprung holder to tap them as vertically up right/ square as possible in to the metal ( as needed ) .
Acids to use ..help !
I have an old lead acid battery that I can steal some 1.25 sg sulphuric acid out of and a few big plastic syringes to do it in safety .
I don't know if it will be strong enough for long enough to etch as deep as I want to go .
My thoughts for etching are that.. there will be no raised burs , all lines should be shown in full rather than a dotted line style if i use a small electric vibrating type engraving tool . I should be able to draw perfectly straight lines with the stellite rod and a ruler .
All advice and merriment gratefully accepted .
.On youtube , I've seen guys being bent over their lathes for hours & hours using the carriage & / or compound slide & a stop block to gouge out the scale devisions .
My thoughts are :
Ferric should work on owt copper based. On steel and such though, it'll just rust it, as far as I recall. For aluminium, caustic will likely work best.
