more than a couple of times now the thermostat/timer has switched the heating on, the noise coming from the boiler (pump?) is the same as normal but no heat to the radiators
I THINK the same thing happened once with hot water (vague memory)...could hear the boiler firing up but no hot water out the tap, solved by switching it off and back on at the wall
it's a Worcester 24i boiler...are there things I can check or even fix on the plumbing side? or will it need a gas safe engineer to look at it?
cheers
cheers
