bert
- Wiltshire, England
I had to descale the Hot water heat exchanger in my worcester 350RSL last night as the hot water pressure had dropped below 3psi and would not trip the flow switch which meant no hot water.
I drained the system removed the heat exchanger and desclaed it, refitted everything and refilled to 1.5bar pressure.
Hot water pressure was back but after approx 20-30 seconds the boiler pressure went up very quickly to just below 3bar at which point I turned off the hot water and the boiler pressure dropped back to 1.5bar.
I tried the central heating and that worked perfectly with no change in pressure and all the rads worked fine.
I found that the expansion tank didnt have any pressure so i reduced the boiler pressure to zero via the Pressure release valve and pumped the expansion tank upto 1bar and then refilled the water back to 1.5 bar but I still have the issue with the pressure rising when the hot water is turned on
I thought that maybe the heat exchanger was holed so turned the boiler off and turned on the hot water tap, the water pressure in the boiler stayed the same so i dont think its at fault.
Overnight there was no change in boiler pressure.
Any ideas as to what the cause could be?
Thanks
Thanks
