Is there anyone on here who can help with a problem I am having with one of these?
When pumping it up to pressurise it, if I release my thumb (before closing it half a turn) from the little hole in the pump all the pressure is released. I know this should not happen as I have had several Coleman burners over the years and they do not do this.
I took the pump off a single burner stove and swapped it over and still the lamp does the same.
I took out the square shaft of the pump and I can see it screws into a a brass fitting. It looks like it has a slot to allow it to be unscrewed with a large flat bladed screwdriver.
I think it is this brass bit that is the problem. Any suggestions?
