It's got play in it. When I put a good cut on it the tool dips below center and digs in.Adjust the apron in what respect?
Yes mate its centered. I have got to make time to clean everything up and put a DTI on it.Hope not telling you how to suck eggs but is your tool centred?
Yes mate tool post is solid. I have also locked up the compound slide.Hello U.K. Racer,
I doubt that you problem is due to the apron, given the location of the tool, i.e. it's approximately in the centres so does not have the leverage to lift it. I would say that the slop is probably in the compound slide, try rotating it to the 90 degree position and try again. If it's better there then that's the problem. I take it the tool post is solid?
Alec
It is weird as it cuts ok and occasionally the tool dips (as it digs in ) usually on a heavy cut.
