Now I know Aluminium is good at corrosion resistance, however I've coated an aluminium water container with Zinc Spray to tidy it up. Will this have a detrimental effect on the Ali?
You have water/Ali/Zinc the water does not touch the Ali and Zinc at the same time so you can't get cathodic reaction from it, but will the Zinc coat damage the Aluminium?
I was going to do the same to my pipework but may not if it will damage it.
If this would be the case, what can I coat Ali in to tidy it up a bit? It's all a bit rough due to being moved about and welded. I can't be bothered to polish it up, I'd rather coat it.
