Does Fusion 360 have a list of available post processors ?Fusion 360 for me, make up a template and you can get a toolpath in seconds.
It has quite a few, they are also quite easy to modify once you put your mind to it.Does Fusion 360 have a list of available post processors ?
The OP has not indicated what machine he has.
I'm currently in the process of acquiring more parts for a home built cnc table.Does Fusion 360 have a list of available post processors ?
Let me re-phrase it.I'm currently in the process of acquiring more parts for a home built cnc table.
I have the steel for the table (main frame), I need to acquire/design the material for the cutting support surface.
Also I have 3D printed all the brackets for the XYZ axis, including the S/Steel tube for the X/Y axis.
Yesterday I ordered the cnc control modules (F2100T includes THC plus Z axis unit and a remote control for following pantern/positioning (my Christmas present to me...)
I need to try to understand/draw/learn/use a cnc computer design/cutting program, because this will be the hardest bit for me......
Next year stepper/drive motors and motor controllers for X/Y axis?
Cutting surface frame.
A fume extraction system.
Then:- Cross fingers hope it all works or it's a waste of beer tokens........
