Hand bags at dawn?youve thrown all my youtube suggestions to the wall
and yet your back here asking same again
if i do find what your looking for will you take note or just ignore like the rest of it
More context? Sorry if I have offended - not intentional!youve thrown all my youtube suggestions to the wall
Hello, you haven't posted any YouTube suggestions on this thread. Wrong thread?youve thrown all my youtube suggestions to the wall
ive posted the vids on other greyhound lures requests by the userHello, you haven't posted any YouTube suggestions on this thread. Wrong thread?
Problem with a treadmill motor is they are normally about 180v dc. I think the reason the Op is wanting to use 12v is so it can be run off a car battery. I would imagine a 240v single phase supply isn’t available in the field where this is going to be usedSurprised that nobody has suggested using a treadmill motor! Huge torque that you can gear up using pulleys & DC powered. If you use the original treadmill gubbins that will give you variable speed control.
Problem with a treadmill motor is they are normally about 180v dc. I think the reason the Op is wanting to use 12v is so it can be run off a car battery. I would imagine a 240v single phase supply isn’t available in the field where this is going to be used![]()
Yep, you would need a couple of batteries. You need to be careful running power supplies of generators, most die pretty quickly as the power generated is not very clean. Same reason why it is not recommended to run computers etc from them.However, Its not the case with all generators, I do know some of the suitcase Honda generators do output clean enough electricity to do it. I unfortunately found this out the hard way when I used to fly RC helicopters and tried charging lipo batteries from a generator.A 12v car battery isn't going to last very long putting out the sort of watts required for this task! Running of a 240v genny would make more sense & those camping gennys are fairly quiet.
Yep, you would need a couple of batteries. You need to be careful running power supplies of generators, most die pretty quickly as the power generated is not very clean. Same reason why it is not recommended to run computers etc from them.However, Its not the case with all generators, I do know some of the suitcase Honda generators do output clean enough electricity to do it. I unfortunately found this out the hard way when I used to fly RC helicopters and tried charging lipo batteries from a generator.![]()
Make it pedal powered and make it into a participation sport. Win a fiver if you can beat the Whippets five times in a row. Open only to kids and you have a free power source![]()
whilst a greyhound race uses a continual line so can you if you consider an oval loop system with a 3 point turn instead of just a sharp wheel back to base thats the killing point as you need to slow down otherwise the whip of the lure can fire offI was hoping to do a quick and dirty version. My run is a lot smaller (probably now only 100m of rope and I would really like it as a continuous loop rather than having to reel it back in between dogs, I also expect I have a lot lighter lure, shorter run and Clumbers are not as fast as greyhounds! The Rumble I have the videos for in the US, show the fastest speed at 10m/s
the RACING whippet club near us use a 12 volt car starter took my working whippet one day and he did real well till he saw a rabbit near the woods and deviated and promptly did the business and brought it backhe never won a prize but they were impressed
