Could you please recommend a good 2k lacquer for coating carbon fibre parts. Up to now I have been using aerosols(Upol #1 being the best so far) but now I want to change over to 2k. I'm looking for a lacquer that will give good UV protection and will have no problems with the epoxy resin used in the CF parts.
Also, I'm just about to buy a mini spray gun, is there any makes to avoid? I only have a small compressor (2.5hp, 25l) so ideally I'm looking for a gun with a relatively low CFM requirement. I have a separate compressor(same spec) for the air fed mask.
