Triumphman
I've got some nice vintage nuts and bolts for use on a job, they're not wasted just got surface rust and oil on them etc what can I dip them in to help clean them up?
Many organic acids won't... citric, acetic (vinegar), oxalic (rhubarb), tannic and probably a few others all work in the same way as molasses/black treacle. Chelation, they eat rust but won't touch good steel.Any form of acid will leave a slightly rougher and likely pickled looking surface.
As you say different metals are different, if i think a part i've got to repair is magnesium i use vinegar to test- can leave steel in vinegar for weeks but it reacts quickly with mag fizzing away producing hydrogenBeing pedantic i did say will eat rust but not good steel![]()
Don't think citric will be so good at removing heavy Al oxide but it's not something i've tried either... i tend to use it as a cleaner/brightener rather than something to soak really manky ally in. Treadplate is the usual suspect due to the textured surface. I think one of the issues of soaking an ancient ally part is that the citric will react differently with the alloying elements- kinda like how a strong alkali cleaner would be followed by desmutting, especially with alloys containing much Cu and/or Si
Have a few ally bits which have done the usual due to moisture exposure, but not too fussed on going the caustic route. I'll try a piece in the citric and see how it fares and post back. End of the day, it doesn't really matter if one of the parts ends up knacked, so I'll give it a whirl. Never even thought to try it 'til you mentioned though.
