cumbriasteve
Moderator
- Cumbria UK
A VAT free MM day looming means I am going to prepare for winter and buy a Clarke pot belly..the £74 one.
My question relates to the flue, if I buy the bits from MM it will cost more than the stove, so my plan is to get some mild steel pipe from the scrappy or even my local steel stockist and cut/weld it to shape myself....basically 2 ups with a short 45 degree in the middle.
Knowing nothing about the stoves...will this be ok if the pipe is a bit of decent thickness, thinking of sealing it over the stove outlet with some of the correct stove paste/cement.
If anyone from Carlisle way has not got the vat free voucher and needs anything, I will be there on Sunday 15th May and can get it on my voucher for you if you want.
Cheers
Cheers
