Hi Guys, I've just found this site after having been given a Clarke Mini Mig welder by the widow of a friend. I was hoping to see a pic of this welder so I could maybe get some info on it. I have no handbook. I think I should post a photo then maybe one of you would recognise it. On the front panel it says Clarke7Mini Mig mk2. There is nothing about Amps.
It has languished in a garage for about 25yrs, with a full spool of wire, and looks clean. When I switched it on, the wire fed through the nozzle. The Co2 bottle is obviously empty. I have never Mig welded so it's something I've got to learn, although I have gas and arc welded.
Together with the welder was a larger cylinder that looks like an ex-fire extinguisher that I guess my friend was going to use instead of the small bottle mounted at the back but it has no regulator fitted.
Fingers crossed some of you might recognise it and give me some info, as well as how to fit an applicable regulator to the cylinder, and where one gets them filled.
Thanks!
Ernie
Thanks!
Ernie
Thanks for replying. I hope you can give me some info on this after seeing the pic. Ernie
