just bought a Clarke 135TE mig welder but the swan neck was missing, I was wondering if anyone knows of a website or place i can buy a swan neck and the connector block?? cheers geth
Yep!
One of these and one of these will sort you out.
Grab some spare tips, a couple of shrouds, a liner and a swan neck spring too, treat the torch to a birthday.
Just out of interest, are you absolutely sure you need the gas valve?
well all I got with the welder was the empty torch body with the wire feed and gas pipe loose inside the torch. Does the Gas valve have Threaded holes at the back of it to accept the wire feed and gas hose?? cheers geth
The threaded holes will be there but if the gas line and wire liner don't have the push fittings on the ends then you'll need those too.
Phone or email Weldequip to check.
ok another question for you lot (:, Im thinking about using the proper gas bottles rather than the dissposable ones. I Have a CO2 pub Tank, is this suitable to use? and were do i get refills?? cheers
co2 is perfectly adequate for what most people need
a fire extinguisher place should be able to do it bor about a tenner
you will also need a CO2 reg with a nut on if the bottle has a male thread
