nickde-ath
Hello again Gents, further to my previous thread (SIP 25031) I would be grateful for your opinions on the above welder. My reasons for looking at this one are:-
Fairly low bottom current, need to weld car body work.
Supplied gasless, I will be mainly using it out doors.
Can be converted to gas mode. I intend to buy the regulator and gas cylinder at the same time so I have the option to do both. Is the pipe work for the regulator supplied in the welder? I can't see any mention of pipe work in the manual.
Says in the manual 13a draw from mains, I want to try and run this from a 2800KVA generator, I'm told this should be OK on low amps.
All replies greatly appreciated.
Thanks and regards Nick.
Unless a welder is advertised as generator safe I would be careful using it from one as spikes can cause damage to both machines. My mig is sold as generator safe but the smallest recommended is 5Kva, the ideal is 8.8Kva.
