The clarke 105TEN uses a dinze of small 10-25mm size (I believe) for earth.
I am replacing the earth crocodile because it bites offset with a hairline scratch on 0.8mm zintec steel when I drag it. Leaning on the clamp made a huge difference to both noise & weld quality on thin metal.
Q - Is it possible to remove the shroud on the Clarke plug?
That way I can just not only crimp a new lug for a 200A crocodile, but also fit a usefully longer length of fine strand 16mm cab rubber cable to it.
