gaz1
- westyorkshire
there's nowhere near the gear about now that they used to be what gear there is most is overpriced due to ebay
{CLEANED AND OILED )I wonder what that looked like before it was 'restored'!
And painted black with a worn yard brush by someone who should have gone to Specsavers{CLEANED AND OILED )![]()
silly boy asking buyer to sort out courier themselves so easy to say they never got it and claim your money back
Thats correct Dan and iff ime honest they make very good lathes, but you need to strip them and rebuild again with a small bit of fine Emery cloth and some decent machine oil..also the Gib screws need adjusting correctly but once set up right they make very accurate and reliable cuts@roofman has one as a back up for the back up for the back up, or at least one very similar buried at the back of the bench
You need to strip and rebuild that texting thumb while you're at it, it appears to have stopped workingThats correct Dan and iff ime honest they make very good lathes, but you need to strip them and rebuild again with a small bit of fine Emery cloth and some decent machine oil..also the Gib screws need adjusting correctly but once set up right they make very accurate and reliable cuts![]()
Dont get cocky just because your working on those Briggs & Stratton engines young,unYou need to strip and rebuild that texting thumb while you're at it, it appears to have stopped working![]()
give over you heathenDont get cocky just because your working on those Briggs & Stratton engines young,un![]()
