Wallace
- Staines, Middlesex, England.
After having read thoroughly the threads on here about this bandsaw, I went ahead and bought one
on a Vat free day for £190 after ordering some new blades for it from Trucut on Chunko's recommendation in another post. I thought I would add a post on here and update it with my experiences and modifications I make to the saw.
Out of the box it was exactly what I expected and have experienced with many Clarke products over the years, it is a very cheaply made tool with many flimsy and barely adequate parts. The manual supplied with it is written in Chinglish and has countless mistakes, the first I came across was which way round to assemble the motor & gearbox drive pulleys as if you fit them as per the manual you cannot close the guard cover!
Once assembled I made a few trial cuts to see how well it performed and I was quite impressed at how clean and square they were as the saw was out of the box with no adjustments. After around 8 cuts I was aware of a clicking noise so I inspected the blade expecting it to be breaking at the joint but that was ok, I found it to be one of the guide roller bearings had split due to being overtightened so I will be onto Clarke about a new one. I have re-adjusted all the rollers and it is currently working ok as is but I have a full set of SKF bearings on order to replace the cheap ones as I don't expect much joy with Clarke Customer Service.
The second mistake (apart from the awful spelling!) I found in the "manwell" was concerning the guide rollers, it states that two are fixed and their opposite roller is on an adjustable eccentric, mine has four eccentrics! Not a bad thing as it should allow a little greater adjustment for a squarer cut but could throw a bit of a curve ball thrown at the uninitiated who read the manwell in the hope of guidance.
The power cable is too short to be of much use and is not remotely flexible as you can hold 18" of flex with the plug on the end horizontal! The bracket for the on/off buttons has nice sharp 90° edges sticking out at perfect knee cap height, so these are two items that will be getting attention as time goes on, another being the wheels and handle. The handle vibrates against the stand whilst in operation so I placed a neatly folded rag over it to quieten it down which did the trick (also giving the impression of a tidy operator using the machine!) but then draws your attention to the miriad of other tinwork vibrating. In use to move the machine, the handle feels like it will pull out of the flimsy tinwork it is bending and the wheels are always at the wrong end of the machine depending on where you want to manouvre it to so I can feel another modification coming on there too.
Despite these gripes so far I am pleased with it as it has the potential to be a reasonably good (non-industrial) tool just not straight out of the box!
More to come...Mike
on a Vat free day for £190 after ordering some new blades for it from Trucut on Chunko's recommendation in another post. I thought I would add a post on here and update it with my experiences and modifications I make to the saw.Out of the box it was exactly what I expected and have experienced with many Clarke products over the years, it is a very cheaply made tool with many flimsy and barely adequate parts. The manual supplied with it is written in Chinglish and has countless mistakes, the first I came across was which way round to assemble the motor & gearbox drive pulleys as if you fit them as per the manual you cannot close the guard cover!
More to come...Mike
Even the pry bar set I bought years ago needed all the sharp edges taken off the handles.
