txargyll
- Scotland, Argyll
hi, a friend has given me his clarke 85 as he is a loss to why it wont work, it used to work just fine, last use was on 0.8mm metal and did the job well on minimum settings....... to him it felt like it was stuck on minimum as it was not getting enough amps when next used 3months later, with 2mm steel set on maximum.
I tried to weld with it, first thing i noticed was that there is no arc unless the torch trigger is pressed which is unlike my Ferm 100 or Kende 105 welders. But i dont think this is an issue but better than my welders as you can position first then get your arc.
The torch swan spins round and on further inspection i see it has no thread so that will be why, the tip was new but i changed it anyway and shroud in good condition, checked the fuse which was good, the wire feed was working as it should too.
The minimum and maximum settings definately change the amps used, but they are both extemely weak. and so the welder is pretty useless. There is no hum from welder when first turned on unlike my own but i reckon thats because its not actually working until the trigger is pulled.
checked all wiring and nothing looks corroded in there, no broken wires and connections all seem to be good.
Live wires are leading up to and are live at the square plates at the back of the welder....... it does purely seem to be the delivery of enough amps that is the issue. on the square plate there is a white plastic thing where there is a live in and out connector...... i took the connectors off, checked getting a live feed and they do, when these were disconnected and welder turned on the switch light came on, so this must be something to do with the duty cycle and would appear to be working as it should.
I also noticed that the swan has within its neck a spiral liner of same length and that there is no brass button on the square block that would depress like on a picture seen on this post.......http://www.mig-welding.co.uk/forum/threads/diagnosing-a-fault-with-clarke-85en.4835/
metal is clean and paint and rust free.
I swapped out the earth clamp as it was not grippy enough.
last thing was to change the flux core wire to one i know works well, no difference
Any ideas where i should look to resolve this issue?
