IanFiTheDwarf
New Member
I have a Clarke 185E which I picked up cheap as it wasn’t working very well.
It seems to be pulsing and stuttering quite badly, I have replaced the torch and rebuilt the wire feed which now works perfectly but its still doing it.
It seems very much like when the little Clarke migs get too hot and the voltage to the feed motor drops when you strike an arc slowing the feed down just enough to break the ark, then it speeds up again and the sequence starts all over again, except the feed appears to be pretty constant so I am assuming it is the currant which is dipping.
My thinking is that being that the welder is about 25 years old the capacitors are probably goosed.
Dose this sound reasonable? Or can anyone suggest anything else I should look at?
Cheers
Cheers
