I'm in the process of replacing my tools for new ones, and top of my list is a welder
I've been lurking around and reading the forum for help, and on investigation and recommendations, I've decided to buy a Clarke 160TM
I'm still a bit of a beginner welder, been using a clarke gas/no gas I was given second hand in the past on the small bottles
So this is the welder I'm thinking of getting:
http://www.weldequip.com/clarke-160tm.htm
This the gas that I'm thinking of getting as they are on the same indutrial estate I work on:
http://www.hobbyweld.co.uk/default.php?page=35
As majority of my work will be on cars, so should be under 5mm
Next on my list is which regulator to get? As with the small bottles on my previous welder, I struggled on getting good flow. Can anyone confirm if the regulator below will fit the bottle hobbyweld bottle and allow for setting flow rate as well as bottle pressure?
http://www.weldequip.com/argon-regulator.htm
Other than that, I have an auto-dimming mask, gaunlets, etc.. so is the only other thing I need to buy a spool of wire to get me going?
Many thanks
Ade
Many thanks
Ade
