Porschemaniac
Hello,
Firstly, I am new to this forum, but having looked at the posts, I am so happy to have found it.
I am in the process of restoring my own personal money-pit (1984 Porsche 944), which will need various buts and pieces of welding. Because of this, I need to replace my current welder.
Currently, I have a SIP Handymate (think it's either 80, or 90 amps). I have to say that I have not been anywhere near the car with this and, having practiced some welds on some scrap 1.5mm sheet, I assumed that I just couldn't weld!! Having read some of the posts elsewhere on the forum, I think it may be more to do with the welder than my lack of ability!!! In any case, it has just started chewing the wire up quite badly, so this, combined with the fact that I want to make good welds on the car, mean that it has to go.
Having read many posts, I have selected the Clarke 151TE as the perfect welder for my needs. My only concern comes down to the power supply issues that others have raised on this forum.
It looks like the consensus of opinion is that it's fine to use this from a doemstic 13 amp supply - which is great. However, the supply cable to my garage is about 20 meters (good quality, thick SWA cable). This is a spur from the domestic ring main, protected by a fused (13 amp) double pole RCD.
I'm guessing that the extra cable run could result in the supply capacity of 13 amp becoming marginal if I'm using the welder at full power? If this happens, I guess it's going to blow the fuse in the RCD unit before the fuse in the welder plug?
Does anyone know what the input current is on this welder at full power? To be honest, I don't think that I'll ever really need to use the welder at full power for long periods, so hopefully, this will not be an issue. Alternatively, if it could be, then I guess that I could go for the 135TE.
Any advice will be gratefully received.
Cheers,
Ian.
Cheers,
Ian.
. I like the cut of your jib though, it is definitely much safer than substituting the fuse for a bolt or a contact tip. You should be absolutely fine running it on 13A anyway, if you were to run it at full whack for long periods the fuse may blow but for normal use it should be fine.
