Hi,
I was happily doing some pulse welding of a new sill on to my Mini and all of a sudden - wire won't feed through. Is it likely to be just the wire feed motor?
I can't tell if the ability to create a spark stopped or if the wire just stopped feeding. I know for sure that the wire isn't welded to the tip and there is no nasty spool of wire inside so the sleeve is good.
Am I looking at a completely dead unit - although the fan still spins:-) or just the wire feed motor?
Would the wire feed wheel turn with the trigger pressed? Is that a good test of whether the motor is stuffed or not?
Thanks,
Rod
Thanks,
Rod
