Hi all,
Does the collective know of anything common where a Clarke 150 Turbo (the blue one) goes......... inconsistent as it's used? I'm guessing temperature related. It's a bit hard to describe but if I start using it from cold it's fine but then after a while welding it seems like it struggles to hold a consistent arc and gets very "splattery". It doesn't feel like a wire feed issue to me and tweaking the wire feed speed doesn't really seem to make a difference. Let it sit for a good few hours and it's fine again which screams temperature to me.
The gas valve seems to have become a bit "lazy" too as it keeps flowing for quite a while when you let off the trigger. I do like the sort of two stage trigger and have the feel of letting gas flow briefly before going to the second stage and feeding wire and striking the arc and then stopping the weld whilst letting the gas keep flowing for a second but it's got to a good few seconds even after the trigger is completely released. I'll sort this if I can get a resolution for the above problem.
I know it's a hobby machine (albeit at the upper end of hobby when I got it) and in the case of mine it's got to be 20 years old so it owes me nothing and has probably earned retirement but it's sort of an old friend and I don't want to just give up and buy another.
