shenion
Tool Pack Rat
- Stone Mountain, GA USA
Been practicing with my 130EN. Thanks for the wire speed vid, I found I was using too low a speed.
I did not realize you could do aluminum with MIG, was under the impression that you HAD to have a TIG.
Been playing with aluminum welding. I can do thin sheets well. Seems it absorbs the heat well. Been trying 3mm stock and the wire just melts back to the tip on the lowest current setting. Really wish the 130 went down to 20A. My power here is 125V instead of "110", so currents tend to be a bit higher.
With steel and lowest current, my speed is set to about 4-5. With Al I need to have it about 8 to keep it from melting back to the tip.
I did find increasing the gas flow (Argon) to about 16LPM helped the wire melt-back issue, but the weld is then tall and a bit cold.
I have been fighting birdsnesting/feed with the 0.30 wire. The tension screw is almost completely loose. Been using an 0.35 tip.
I have some questions:
1. I checked a source here and they have a Nylon-liner (requires and adapter?) I think this will help feed, but the liner says "0.35 Aluminium wire" Can I use it with steel wire? Maybe it would wear out the liner. The 130 has a fixed lead, so I can't plug in different cables when switching between Al/Steel.
2. I think moving to 0.035 wire (0.9mm) will help feed and the wire burnback and penetration.
3. I assume I would use an 0.045 tip for 0.35 Al. Cant seem to find them locally.
I'm tempted to make a nylon wedge to fit between the rollers and feed tube, or at least grinding the end of the tube to a V and getting it closer to the rollers.
Of course, a spool gun would probably be best, but these cost more than the welder itself.
Thanks to this site, I can do decent welds with steel. If I can add Al to my bag of tricks I can fab some custom mufflers for my R/C planes (most have chain-saw engines.) I could also do some repairs for "Sudden overdose of ground"
