Hi everyone,
This is my first post, but I've been lurking for a while, trying to work out what kit I need.
I restore old cars as a hobby, and do trimming/upholstery on them as a part-time business. My welding needs are:
* Welding the odd bodywork repair (probably only outer panels, no thick chassis/legs.
* Making the odd repair to seat frames, attaching tabs to seat frames, repairing smaller parts like rusted out window grips, mounting brackets etc.
While I can do a lot of the smaller jobs indoors, I don't have a garage so would have to weld bodywork outside on the drive. I also don't have a lot of storage space in my workshop (it's already full of tools an upholstery equipment and supplies). And I don't have much cash really. I'm unlikely to do a lot of welding.
I've not had any training in welding, so will need a lot of practice (I have an old bonnet I can chop up and use for practice).
I'm thinking my best bet is for gasless MIG - no bottles to store/rent, which given I won't be doing that much would probably end up being not very cost effective. It'll also save having to try to set up windbreaks outside (I live in Sheffield, where it's very rarely still).
I know gasless isn't as easy as normal MIG, but perhaps the fact I'm learning from scratch might mean It's easier than re-learning?
I think buying second hand isn't a great idea as I've no ability to test second hand gear as I can't weld yet, so am likely to buy a duff one!
So...
I'd like some advice on whether the Clarke 102NG. I can't find any mention of it on here, but I think it's pretty new to the line up. Do you guys reckon this would be able to do the occasional bit of bodywork (using an ali or copper block as a heat sink where possible to reduce blow through), and tacking together things like seat frame tubes?
It looks like it has a decently low min amps (35), and goes up to 90, which I think will cover what I need. And it has the advantage of being cheaper than the other gasless Clarke welders. It can't be converted to gas, but then I'll probably never want to, given the likely cost in any case.
Any advice very much appreciated.
Thanks
Mike
So...
Thanks
Mike
