Got my welder last week and hope to get it fired up tomorrow, once the cylinder valve keys appears.
Just been having a look at the torch, after looking at many many posts and the tutorial videos, I thought the tip had to be between just proud of the shroud for corner work, or level/just inside the shroud for normal work. The torch tip on the 160tm seems to be back inside the shroud maybe 3-4mm. Is that to much, and if it is, how do I go about adjusting it? If I unscrew the tip so it closer to where it should be, it wobbles about due to only being held by a couple of turns of thread. The shroud won't go back any further either.
