Benthosboy
One of life's pillocks!
Latest in a long list of projects is wide-load mirrors for the wagon.
Quite simply, I want to clamp a 200mm length of 30 x 30 box section to the underside of the mirror arm, which is 30 mm diameter tube. Into that will slide a length of 25 mm box with a mirror head clamped on the end, all clamped up via nuts welded to the 30 box and clamp bolts, all galvanized and powder coated.
Anyone know of a source of clamps for said box-tube? At the end of the day, I want it to look good so jubilee clips/cable ties/bodge tape, etc, aren't an option. I was pondering a tv-style aerial clamp but they all seem to have some form of V bracket with large "teeth" which will spoil the look of it. Welding lugs for "U" bolts onto the 30 box is no problem if needs be. Stainless hardware always works for me, saves it rusting and looks better.
Thanks, as always.
Thanks, as always.
