I need to clear some light rusting from inside of a small petrol tank and am going to use citric acid but what ratio do you need to mix the citric crystals. Thanks. Pud.
This is the best way to ensure you are dissolving all of your acid. The reaction is typical in that it responds very positively to temperature. I always dissolve mine in hot water before diluting to taste. The actual concentration is less critical since you an make up for a weak solution just by waiting longer.
The key is temperature though and if your acid is a lot colder, you'll be waiting a lot longer.
