Hi,
As part of my turbo manifold, I'm using the above mild steel tube with 5mm thick wall. The tube is welded down the seam, the weld externals a few mm inside. It doesn't look particularly fused to the surface internally (the excess).
Obviously the weld holding tube together is solid. But, how strong is this excess protruding welding usually? Because it's pretty turbo, should I attempt to grind this excess off just incase is dislodges and enters turbo?
Luckily I'm using pie cuts so it's possible to access. I have access to a carbide grinding drill bit. Will that do?
Cheers
Cheers
