Another chimney question sorry, but Im in a bit of a pickle and I know theres some knowledgeable peeps on here. Id ask on diynot, but it would end up with loads of people just quoting from regulations which arent applicable, I could do with a dose of common sense and experience instead
Ok, Ive got a 50Kw hs tarn gassifying wood/oil furnace and got it inside the house into the utility room without demolishing anything (a tale in itself...), but need to fit a chimney. Ive been told by lots of people to keep the chimney inside, or it wont draw properly so Im attempting to do that plus the exit to outside involves a fragile cob wall which Id rather not carve a 120mm hole in and weaken any more.
I need to penetrate the next floor's joists which are at 500mm centres and by a lucky chance it looks like I can hit the 250mm dead centre with the centre of the chimney to do so. But Ive got two bits of flue, one 180mm stainless single skinned one, and a elbow of 150mm single skinned. The furnace has a 150mm outlet.
If I go out and get a 7m length of 150mm stainless flexy flue, can I cut and jam or tig in small steel spacers between its exterior and the 180mm single skinned tube and create my own cool wall flue and say leave a 50mm airgap between the exterior and combustibles ? Maybe fasten some reflective steel plates on the joists etc and skin them with fireboard to be sure. Belt and braces. Downstairs the flue will be 300mm from normal plasterboard fastened onto metal richer rail system, does that need a skin of fireboard too for security?
Ive just been the local suppliers and theyre predicting mid jan before they can get me a real dual skin coolwall flue in the diameters I need, and right now its -2, and we're predicted to hit -8 by the weekend and theres no heating / ufh system has water in it already and a 5kw electric space heater isnt keeping pace, so getting the heat source hooked up is quite urgent, but so is not burning down the house in the attempt...
We'll be running on wood alone until jan if thats relevant.
