Just thought that i would mention on here,For the past year i had been using 6mm wire with gas and i had not been really happy about the welding,In the past month or so i decided to change to 8mm and what a difference it has made to my welding the knurling on the 8mm side of the feed rollers let the wire go threw nicely the welding looks the business.You may say that it also depends on what I'm welding ! Its just usual things i needed to weld a broken bracket about 1/4 inch thick no prob.Now if i did car panels i would probably change back to 6mm ..But i think from now on will stick to 8mm so any newbies having problems welding try 8mm wire/tips.
