Ton-up
- Essex, England.
Hello all,
I have a Stihl MS170 chainsaw that I use a few times a year. I was using it a few days ago, and after about an our of use, with no problems, it suddenly lost power when cutting.
The saw starts, ticks over and rev's fine (maybe a bit less max rev's than normal, but hard to tell) but as soon as you put the chain on wood, it bogs and the clutch slips, and engine carries on running slowly.
The chain is fine and I have swapped the chain, bar, spark plug and the have taken the carb off, cleaned it out and still no difference. I then emptied the fuel tank and refilled it with new fuel mix. Then changed the carb for another good one I had.
Still the same, lack of power.
So, any suggestions where to go from here please!
