addjunkie
- Northumberland. Reet oot in the sticks
Today my central heating to the upstairs and porch has decided it doesnt want to work….
Before I delve in, in the morning Ive a question or two.
So boiler ok, underfloor down stairs all working a treat, upstairs and hot water are on separate two port valves, common pump. So with hot water on pump cuts in and out no issue, and actually pumps. So Im thinking two port valves to the upstairs heating not playing. Very stiff to open manually, and stays open when heating switched off.
Am I correct in thinking that the little micro switch in the two port actuator needs to show the valve open before the pump gets a run signal?
