S saintnz New Member Messages 6 Aug 21, 2011 #1 I'm after a Tig torch/lead for the above welder. If someone can point me in the right direction on what to buy, it will be highly appreciated. Thank you
pedrobedro Man at Matalan Messages 13,117 Location CX near Chesterfield Aug 21, 2011 #2 If you get an adaptor you will be able to use a cheap valved scratch start torch from ebay. A WP17 is a good compromise between power and size unless you will be using full amps a lot then you need a larger torch like a WP26.
S saintnz New Member Messages 6 Aug 28, 2011 #4 http://s1228.photobucket.com/albums/ee443/Teflonnz/Fabrication/ I brought this welder secondhand (cheap) but I can't find any info on it. Above are photos of the internals - still in the process of sorting out a torch
S saintnz New Member Messages 6 Sep 9, 2011 #5 I ended up buying an WP-17 torch from China - I found the 7pin Cemont plug locally. HF is working fine. The two pins I used are circled in the photo below:
