dstealth
Citroen Restorer
Hi, I have recently gotten the above mentioned TIG welder and being totally new to TIG I haven't a clue which Tungsten electrodes I need or the correct type of filler rod. Through research I've realised that there is diffrent 'bands' you can get for the tungsten electrodes such as red and grey etc. I'm only going to be working with mild steel and to practice with, probably scraps of 1.5mm - (is this too think for this machine?).
Eventually, I will probably be using it for my restoration project - a Citroen DS whose bodywork is a lot thinner than 1.5mm!!
So, question: any recommendations on the type of filler rod I need and tungsten electrode, both for 1.5mm mild steel and whatever DS bodywork is? Here are some pics of the welder:
When I get these consumables along with a bottle of argon and get it fired up, I will probably be back on here asking how to set the pulse and the amps correctly
Cheers
Chris.
Cheers
Chris.
