foy9999
- East Kilbride
Ok so I think I've found a solution, using plastic downpipe I had lying around....
The pics will show better than words but basically I had some (probably) obsolete downpipe that is a smaller OD then the normal 69mm stuff you get everywhere.
The old stuff fits quite easily into the standard stuff so I hoped it would slide into the cast and could be bonded somehow to the plastic downpipe. Acting like a spigot basically.
Turns out it was too wide to fit in the cast so I slit it then removed a strip and due to its natural spring it is a tight fit in the cast.
Next thing to do was put the downpipe over it but obviously it's no longer a snug fit in the downpipe (as its OD has been reduced).
I therefore cut another bit of it to act as a collar. That fits over the slit part (inner sleeve) and reduces the gap between the sleeve and the downpipe.
I then puttied the gaps between the 3 parts.
So water now comes down the downpipe and over the putty on top of the collar and sleeve.
It might be better if the parts were all bonded together in the downpipe so it could just be lifted in and out of the cast but it seems to be working fine (was raining today and no drips).
The only downside is that the old, badly-cut (smashed?) part of cast is now visible at bottom of pipe. This was previously covered by an upside-down pipe-socket.
If the customer is bothered by it will need to paint it black. If they are really bothered by it will need to remove everything, cut the cast just below ground-level, buy new downpipe and make the connection again
We shall see....
previous artisans left this showing when installing plastic drainpipe
it was covered by (straight) pipe-socket allowing water to drip out
correct end of (straight) pipe-socket does not fit into cast pipe
standard downpipe will not fit over cast
possible solution using narrower downpipe inside 68mm to act as sleeve/spigot
narrower downpipe also too wide to fit inside cast
overlap needed removed
new sleeve is tight fit in cast
yellow area and between pink and blue have been packed with putty
We shall see....
