angellonewolf
- bristol england
ok as ive done this in the same house before and some of the gripers have come loose this was some down to a powered wheelchair being used as it draged the carpet but also when i put the griper down they needed quite a bit of hammering to put them down and the amount of vibration with the hammering ment the first nail would go in but by the time you got to the end of the stripe the other end had come loose
i was chasing my tail for quite a while the floor is concrete with those tiles aprox a 1mm thin so as you hit them some come loose some cracked some it went throught fine when i go back i want the job jobed right with as little problem as possable
so im going to remove any loose strips and reattach them so im hoping just nailing will work but want to go bolt and braces so should i just glue the strips down (and do they do an hour dry resin for such)
glue and nail down?
dont realy want to drill and screw as there are pipes for heating under neath the concreat floor
any input wil be great full
glue and nail down?
