I've not got an 8mm steel to compare, but on my worn out ML7 I can't tell the difference between a 12mm steel and that 8mm carbide, both use the same insert.C08M-SCLCR06, that one would do. How does it compare to to a steel one of the same size for flex?
am really looking to standardise with as few insert sizes as possible.
carbide bars are superb compared to steel, you can stick them way out to 5x D, maybe 7x D and they don't chatter half as bad, even the cheap bars.C08M-SCLCR06, that one would do. How does it compare to to a steel one of the same size for flex?
I did 85mm long 12mm bore in O2 steel with the 8mm carbide bar I linked above, it was not fun, ended up taking tiny cuts with an aluminium type insert. Definitely a one off hobbyist kind of job, wouldn't be making money like that.a magic fix for trying to stick out say 10x D, or something stupid like that![]()
Aye, superb wee bars.....as I have another 08 bar made by mitsubishi that uses tiny trigon inserts, and that bar is magic.
Or a toolmaker.I did 85mm long 12mm bore in O2 steel with the 8mm carbide bar I linked above, it was not fun, ended up taking tiny cuts with an aluminium type insert. Definitely a one off hobbyist kind of job, wouldn't be making money like that.
I don't have the patience for that kind of thing, it would be a drilled hole if not critical, or I'd buy a reamer if it was critical...I did 85mm long 12mm bore in O2 steel with the 8mm carbide bar I linked above, it was not fun, ended up taking tiny cuts with an aluminium type insert. Definitely a one off hobbyist kind of job, wouldn't be making money like that.
Link or details pleaseI have another 08 bar made by mitsubishi that uses tiny trigon inserts, and that bar is magic.
