ajlelectronics
- Gloucester, England
This caravan has a load of manky old steel pipe which I am discarding. There will only be one gas appliance which is a two burner oven and hob. It is currently not fixed into place for some reason.
My questions are as follows:
It is my understanding that final connection and test can only be done by someone with the right piece of paper? I see from the regs. that I am permitted to do it on my own vehicle if competent, but not on someone else's.
The oven must be fixed into place, that is obvious even if rubber fed all the way.
I can bring in new flexible gas hose from the regulator but then it needs some sort of quick connector. Otherwise the regulator will have to be disconnected from the bottle and then the problem arises of what to do with the regulator during transport.
For a fixed pipe, I anticipate a short length of rubber from oven to rigid, can this connection just be a pushed over and clip type, or do I need some fancy crimped connection? 8mm standard copper pipe and standard compression fittings good enough?
edit:
Some of that appears contradictory. A compression fitting (though I wouldn't use PTFE anyway) is surely a threaded connector?
I'm sure I just know these by different names, but...
What is a "cutting ring connector"?
In this context, what is a "capillary connector"?
A flare connector, would that be a bell mouth as per brake line flaring?
How about fittings for rubber to spigot at the oven end?
Gas pipe needs to be rigidly fixed to the structure and not allowed to move?
As I can't get a gas bunny with relevant papers in time, my thoughts are to install the rigid and flexi to the oven and leave the regulator end to said relevant bunny with papers. I would imagine that if I connect it all up to be useable then I am responsible for its safety? Ventilation isn't an issue, there are more gaps and holes than you can shake a stick at. Customer has been told to get smoke and CO alarms PDQ, especially as she also has a wood burner in it!
edit:
Gas Pipe Fittings
- Permitted gas pipe fittings are; cutting ring type, capillary, flare, compression and threaded fitting for nozzle.
- PTFE tape must be used on threaded fittings.
- PTFE tape must not be used on compression fittings. A compression fitting is not sealed by the thread, so applying PTFE tape may cause a leak.
(apologies to
