DAPPH
as dyslexik as I'm daft
I purchased a single axle Rhyno motor mover for the caravan about seven years ago .
The caravan has only done four trips out with it on till disabilities took me off caravan for a couple of years , none of the trips was in wet weather. Sold the caravan & got the mover transferred to the new caravan three years ago only one trip since due to more operations & recuperations I used it once a two weeks ago for three days to go to the film studio cum the world of Harry Potter( Magic ).
It didn't not much rain either but it seemed difficult to park it up so on coming home I reversed it into it's position then my lass & 16 yr old daughter pushed it to its final resting place as the parking is on flat floated concrete.
Came to start checking it over & servicing it for a run down to Devon on Monday The rhs mover would not work , I could hear it singing as the power went through the windings but not a fraction an inch of movement .
Ha ha I thought the dreaded grit in the bearings seizure I've heard so often about .
2x 17 mm , 2x 10 ,, 1x 8mm socket & driving ratchet and a 4 mm Allen key pus a pair of nippers to snip the cable ties . 20 min later it was free dangling by it's wires. Another 1/2 r and copious cooling drinks & that too is sorted the baby is free,trailing 12 feet of umbilical cables in black & red ….. Yeah! ..success .
It took longer to get the gear together & find something comfortable to lay in in the boiling hot sun than to get it off.
It was boooooger to strip apart , I found put why. The ferrite magnetic strips that should have been fixed internally to the motor body casing had all come free & attached themselves to the stator.
Careful examination revealed one magnet had a deep water stained crack in it & it was in two pieces at the crack .
On looking at what should have held the magnets in place I was dismayed to find the remnants of what looked like Evo Stick contact adhesive or Copydex rubber glue , It had been brushed on over a coat of paint .. every bit of the paint had lifted off because it was full of rust under the paint.
I'm in the pocess of using some paint stripper to remove the glue residues & the paint . then I'll poish the body tube on the lathe till there is no evidence of paint or rust .
Then I'll rust treat it & use araldite to put the magnets back in place .. Hope I get the polarity right or I'll have to swap the live & negative wires round at the control box ….
Do any of you have any tips as to how I should put the magnets back in ... say for instance go clockwise & have the north end of the magnets at the leading edge ?
Some thing to do with Maxwells law me thinks .
