Islander71
- West Scotland
I have a mk1 Santa Fe 2.0crdi which has been a good car over the 3 years I've owned it, now with 178,000 miles on it. A few weeks ago it started not starting - immobiliser problems - but eventually after inserting and removing the only key it has always started. Cleaned the connections from the immobiliser coil to immobiliser connector which I think has helped, but a couple of days ago it cut out while driving. Its now done this repeatedly. It turns out if the revs go to near 4,000 it just cuts the engine and shows a fault code U0008 high speed canbus high. The engine also runs on for a second or two after turning off the ignition which its never done before. It is still driveable, just, if I keep the revs low, though I think down a bit on power.
Yesterday I took apart all connectors I could find including the ECU ones and sprayed with contact cleaner before reconnecting, tried disconnecting the battery for a couple of hours, have tried erasing the fault code, ( have a basic OBD reader) but nothing has worked. Cann't see any chaffed wiring, but there are an amazing number of bundles of fine wiring. I am now at a loss as to what to do as I dont think there are any auto-electricians on the island. Is it time to scrap it or does anyone have any suggestions as to what may be the problem?
