Gareth J
- North Cornwall
I can access the cavity with a spray tube from inside the car once the outer sills are on but what's the best product to use? The issue with the Micra is that water runs down inside the door pillars and sits inside the sills.
If there's built in water traps, maybe you can redesign the area to let water drain away rather than sitting. Even drilling a hole at the bottom of the door pillar to the outside will be better than letting it fester in the sill. If lots is getting in, there may be an issue with seals above or blocked drains in catch trays.
